CVH Idle Speed
Old Oct 13, 2009 | 07:20 PM
S2Steve's Avatar
S2Steve
Default CVH Idle Speed
My RS seems to have a rather low idle, it did have an air leak but i've sorted that. It seems worse when hot, goes down to about 500rpm instead of 6/700 when cold. Can i adjust this without undoing the good work jamsport did? Or is it to do with hot air and the K&N not being shielded at all?
Old Oct 14, 2009 | 08:46 AM
S2Steve's Avatar
S2Steve
bump
Old Oct 14, 2009 | 10:03 AM
noddysfocus's Avatar
noddysfocus
try the idle speed control valve matey!i had a problem similar with an air leak and i changed that aswell and its fine now!there only about £40 i think from ford!
Old Oct 14, 2009 | 10:29 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
have you tried adjusting the throttle stop?
the big knob under the throttle body, just give it a little turn, that should sort it out for you.
Old Oct 14, 2009 | 11:00 AM
darrenb16two's Avatar
darrenb16two
Try cleaning out the throttle housing, bet its caked in shit. Then set the throttle stop under the housing
Old Oct 14, 2009 | 12:53 PM
S2Steve's Avatar
S2Steve
I will try the screw tonight, i presume its the one with the spring arround it?
Old Oct 14, 2009 | 01:09 PM
darrenb16two
Thats the one mate
Old Oct 14, 2009 | 01:12 PM
S2Steve's Avatar
S2Steve
Sweet, i'll looses it off once its up to running temp
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
