Focus ST170 Acceleration Problem
Old Oct 13, 2009 | 07:10 PM
djdan2k8's Avatar
djdan2k8
Default Focus ST170 Acceleration Problem
Hi everyone My Parents have a 2003 Focus ST170 and for a good few months now on and off when the revs reach about 4-5k it judders like mad.
They had the RAC out to it a while back and he took one of the pipes off i presume the Cannister Purge Valve Can anyone help me out with this problem as it is really annoying thanks in advance with all replies..
Old Oct 13, 2009 | 08:53 PM
Sp3no's Avatar
Sp3no
I would try looking at the fuel pump, but change the fuel filter first. Check its got the right plugs too, ST170's have different plugs to the 2.0L zetec and 9 times out of 10 you get Zetec ones fitted. Coil pack also has a habit of playing up. At them high revs the VVT and Dual stage manifold runners switch over, could be the VVT controller, but if there is no fault code its very difficult.
Old Oct 13, 2009 | 09:45 PM
djdan2k8's Avatar
djdan2k8
thanks for the reply ill take a look and reply to let you know the outcome
Old Oct 13, 2009 | 09:48 PM
gray29's Avatar
gray29
Default had the same problem
had the same problem found it to be the fuel pump after a few months of fault finding, very common, also check runner control, but would bet it's the fuel pump
Old Oct 13, 2009 | 09:49 PM
djdan2k8's Avatar
djdan2k8
thanks gray i did think about the fuel pump but wasnt entirley sure
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
Aug 28, 2015 01:32 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
