ZVh cambelt route!
Old Oct 12, 2009 | 09:35 PM
MikeXR2t's Avatar
MikeXR2t
Default ZVh cambelt route!
hi guys, im currently building a zvh and need to know which route to take with cambelts. ive drilled the zetec block and fitted the adapter plate but am not overly happy with how it all sits! i know this is how pretty much every one in the country is done but feel there could be a better way! if the zetec water pump is used you can swap the plastic rollers on the pump over and discard the larger so just the small one sits on the left then aquire a 99 tooth cambelt from the american 2.0 ofund in the escort, focus or tracer. the only drilling that is needed then is for the cvh tensioner to fit just above the water pump. from this it looks like the belt will get better contact area with the pulleys. is there a massive flaw in my plan or have thousands of people missed an easier conversion?
mk1turboestate
Dec 2, 2015 08:31 PM
Chas
Oct 5, 2015 07:13 PM
davidfordrs
Sep 23, 2015 02:26 PM
davidfordrs
Sep 21, 2015 04:23 AM
pieterjan
Ford Focus RS
Sep 17, 2015 06:17 PM
