cosworth 2wd brembo 4 pot adapter brackets £65 delivered
Hi, i have a pair of these brackets for sale at £65 per set with free delivery to u.k
i have for sale a brand new set of aluminium adapter brackets and stainless steel spacers that allow fitment of brembo 4 pot calipers to the 2wd cosworth hub.The type of calipers that i use can be found on the focus RS, fiat coupe turbo and some alfa gtv s, .these brackets have been designed and developed by myself with the help of my local engineering firms ,metmachex to name one.The brackets are made from 16mm 6082 t6 condition alloy and the spacers are made from 303 stainless steel.The brackets are designed to be used with the focus RS 324mm discs , whether standard or uprated, and suitable pads (focus RS, fiat coupe turbo and alfa gtv s that have brembos).these kits produce excellent stopping power over the standard 2wd cosworth set up and can be set up for a reasonable price.please note that the calipers will have to be slightly modified to fit properly, if you look at the pictures you ll see that there is a notch filed out and there is a bit chamfered off near one of the bolt holes, it s a very easy mod to do. i can pvovide detailed info on this if needs be . or if you wish you could send me your calipers and i ll do the mod for you for a small fee.i can also supply the brackets in a anodised black finish for an extra £10 .please pm me with any questions .brackets come with spacers and bolts and washers and are £65 per set. heres a few pictures.also this kit will fit behind "17 or larger rims.
Oct 9, 2015 07:38 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
