Escort van tow bar
Old Oct 12, 2009 | 04:39 PM
GoldenBitz's Avatar
GoldenBitz
Default Escort van tow bar
hi guys i have just bought a second hand tow bar and electrics and was wondering if anyone had any pics or sheets on how to install them i know its off a escort van so i know its the right one but if any one had any pics or fact sheets to help me plz
thanks guys
Old Oct 13, 2009 | 03:22 PM
GoldenBitz's Avatar
GoldenBitz
or even a pciture of there vans towbar would help
Old Oct 13, 2009 | 06:45 PM
The tow bar should be obvious, the electrics are simple to do, look on www.towingandtrailers.co.uk
There is a excellent simple top follow piccies there, but if you get stuck pm me.
One thing you need also is a audible indicator(buzzer) but again these are easy to do.
When you connect up the earth wire(white) don't put it into the ford loom, but onto a CLEAN part of the cars body(inside), if you need to power trailer/caravan batteries then you will need a 12S(S=Supplementary) socket also, again straightforward to do.
The standard or Normal socket is the 12N and black in colour, whereas the 12S is grey, or has a grey cover to distinguish it, pins are different so can't be accidentally plugged in wrong either.
If you can solder, this would be best for the connections into the rear light loom, but you will need to pass two wires to the other side to pick up the tailight and indicator on that side, scotchlocks are best avoided for reliability.
Old Oct 14, 2009 | 07:24 AM
GoldenBitz's Avatar
GoldenBitz
wow thanks for that reall appreicate al lthe help thanks
Old Oct 14, 2009 | 07:22 PM
No probs at all matey, glad to help, got to finish mine in the morning.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
Mxkid
Aug 31, 2015 10:02 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
