weight. zetec se VS zetec-e
Old Oct 12, 2009 | 09:35 AM
alex182's Avatar
alex182
Default weight. zetec se VS zetec-e
hi, just wondering about the weight diiference between the alloy zetec-se 1.7 block compared to the cast 2.0 zetec-e one.
the reason i ask is the i want to put the 2.0 silvertop in a puma (which usually has the se engine in) and would it upset thhe handling much??
thanks, alex
Old Oct 12, 2009 | 08:54 PM
JesseT's Avatar
JesseT
Yes it would. I have two -99 stw mk1 Foci, one with the 2,0 engine (cast iron) and the other is the 1.6 all aluminum Zetedc-SE Yamaha engine. First of all, the external size difference is very noticable, with the SE being much more compact. Secondly, the steering response is very different, with the lighter feeling much more like a go-kart and the 2.0 more like a Volvo.
If you ain't going to turbocharge it, just use a Duratec-HE instead.
Old Oct 12, 2009 | 09:21 PM
OldDan's Avatar
OldDan
Zetec-SE is around 80kg I think.
Zetec-E is 120kg or so.
Quite a difference, playing around with spring rates would help. Duratec is just as light as the Zetec-SE so would be my choice. Quite cheap to buy too now.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
focuspower
Sep 20, 2015 03:51 AM
