how for does your brake pedal travel on your s2?
Old Oct 11, 2009 | 01:48 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default how for does your brake pedal travel on your s2?
as above mine is about 2 3rds of the way down after i just done bleedin my brakes
Old Oct 11, 2009 | 04:05 PM
Rob_DOHC's Avatar
Rob_DOHC
mine travels quite a bit too, but that is with cosworth brakes and the abs modulators still plummed in.
I would be tempted to give it another bleed, with the rear end on load ie, using ramps or axle stand under the swing arms (if you haven't all ready)
Old Oct 11, 2009 | 04:08 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
i bleed the car with the wheels on the floor, i cant keep bleeding as i have no air in the system, well i dont think i have anyway
Old Oct 11, 2009 | 07:04 PM
Rick's Avatar
Rick
get the brake system hot, and then bleed.
Old Oct 11, 2009 | 07:06 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
how will this make a differnce?
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
