spot the fault
Old Oct 10, 2009 | 10:28 PM
benjaminsarmy's Avatar
benjaminsarmy
escort rst cosworth rep
Default spot the fault
theres a fault with the inlet pipes some where can some one check see if i fitted this rihgt ta ///
Old Oct 11, 2009 | 10:01 AM
gup's Avatar
gup
on the map senser their should be a restricter on it cant really c in the pics properly
Old Oct 11, 2009 | 10:53 AM
benjaminsarmy
would that cause a problem to the map sensor
Old Oct 11, 2009 | 11:11 AM
Graceland's Avatar
Graceland
Team HOTHOT!
That "restrictor" is an air-dryer to stop moisture getting into the MAP sensor - We don't have them on Cossies due to the location of the map sensor and the way the pipe is run.
Can't see it being an issue if it isn't fitted
Old Oct 11, 2009 | 11:26 AM
benjaminsarmy
is this better size
and why will my car not boost up it only able to use vac then boost nothing
Old Oct 11, 2009 | 11:28 AM
benjaminsarmy
tankybaby66
Feb 6, 2016 02:24 PM
DixieTheKid
Sep 14, 2015 09:04 PM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
