Engine age????
Hi ... need some help pleez peeps .... i have a mondeo 2.0 in my escort which has been de catted ... now its MOT time and i dont know anything about the engine other than its a 2.0 .... how do i find out the age of the engine and will i need a mondeo or an escort cat???
Cheerz in advance
Cheerz in advance
find engine number then use the engine date table in the burton power catalogue/website to date your engine.
What is it on your logbook???
If its a car pre aug 1992 then no cat needed even if you fit a brand new modern engine.
If its a post 1992 car then there is a rule in the MoT test book that allows you to have "engine age" related emissions test, but a picky MoT man will want to see the correct engine on the log book to do it as well as proof of engine age. Its how you can get away with dirty cossie engines in new focus's etc, although to be fair the modern mapping skills of such likes as MSD etc means you can get a high power cossie through CAT mot tests no problem with the right map.
Vehicles Fitted with a differnt engine
Test according to which is older, engine or vehicle.
e.g. A 1995 car fitted with a 1991 engine (of whatever make), test to 1991 standards for emission purposes.
Note: The onus is on the vehicle presenter
to prove engine age.
youll only get away with no cat if you can prove the mondy engine was one of the very early pre aug 1992 zetec engines.
Or find a dodgy mot man
or grind off old engine number and put on any one you want!!
