Bara Box for sale
The box is same spec as that was run in the Reyland 3 door. Uprated gear kit, slightly shorter 5th,uprated v/c,new syncros,standard main shaft and standard cut 1st gear,will come with shift cradle fitted with R&B short shift. Only covered 400miles since rebuild, covered 0 miles since i bought it. £3200.
the kit alone is 2900
then has to be built up in a box (more money )
uprated VC is 250
uprated 1st gear is 250
I'm located in postcode BH20, Dorset, can be delivered for the right money, won't take the piss on mileage, either that or collection only.
uprated VC is 250
andrewmctiernan
Sep 8, 2015 03:05 PM
