Mk2 mondeo gear linkage?
My mondeo has lost all gears, even with the clutch up, I can select gears with the engine running, so I am assuming the linkage has come off
... What normally breaks/ is it an easy fix?
depending on year they are cable or rods, being a mk2 it will probably be rods. there are two which attach to the bottom of the gear lever.they push on like a ball and socket, seems a bit odd that both would have come adrift presuming it is that.
wowk
Mar 30, 2021 07:49 PM
Kiran1600E
11
Oct 2, 2015 11:35 AM
The Enigma
Sep 29, 2015 10:31 AM
, both linkages are connected and moving, but got no gears. Think it is a dead box, so car is going in the bin
