rs brakes on a 1.6 focus
Old Oct 7, 2009 | 09:55 PM
yhyhboi's Avatar
yhyhboi
Default rs brakes on a 1.6 focus
i have a 1.6 51 plate focus with drums at the back just wondered if the rs brakes would fit on front and rear if any1 knows is it hard if it can be done cheers
Old Oct 7, 2009 | 10:36 PM
Sp3no's Avatar
Sp3no
To fit RS brembos you need ST170 hubs for starters, then you have to go about getting brackets made up to take the calipers, its not as straight forward as most think, the best and easiest upgrade you can do it ST170 300mm disks and calipers, you need the ST disks, claipers, and hubs but with the right parts its a straight swap no fabrication required.
Nov 3, 2015 04:08 PM
RSBryden
Sep 6, 2015 08:39 PM
gavt123
Sep 5, 2015 10:03 AM
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
