Rewire radiater fan ???????
Old Oct 7, 2009 | 06:48 PM
scooter1980's Avatar
scooter1980
Default Rewire radiater fan ???????
Anyone know how to get rad fan working automatically on xr3i mk5 ive got it on a swich and its anoying,does anyone know how to make it work properly without messing about in the fuse box cheers
Old Oct 9, 2009 | 10:16 PM
martysmartie's Avatar
martysmartie
I would imagine if it's running off OE loom the fan switch went and then someone bodged it with a normal switch. Check the fan switch wiring, it's on the thermostat housing on CVH XR3's not sure about Zetec ones it may just be as I said and someone coulden't bother to sort the switch and just spliced into the wiring with a normal switch in which case all you need is a new switch but these don't usually give problems.
Check your battery to see if you have wires and a relay near it, this would indicate someone has attempted to rewire which isn't a bad thing to have done.
Martin.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Chas
Oct 5, 2015 07:13 PM
