Little ends....
Oct 4, 2009 | 07:41 PM
Little ends....
..... anyone changed these before, are they worth changing as i'll have the pistons out, do they wear much??
Cheers!
Oct 4, 2009 | 07:49 PM
Quote:
Originally Posted by
Karlos G
Cheers!
any time i have ever done a little end in it has fucked the piston mate.
Oct 4, 2009 | 08:00 PM
Ok so as long as there is no obvious play/wear they should be ok to leave as they are?
Oct 4, 2009 | 08:09 PM
If you had no noise from them before i would leave alone as long as the mileage is not too high. or get the opinion of the machine shop?
Oct 4, 2009 | 08:35 PM
I've been given a whole bottom end Louie so have no idea what they are like or how many miles they have done, i'll get them checked over!
Oct 4, 2009 | 09:06 PM
if there ok mate i wouldnt bother
Oct 4, 2009 | 09:17 PM
avoid getting then ground, you'll only make them weaker.
get it checked though.
GTRg
Feb 23, 2015 06:45 PM
G1EN
76
Nov 17, 2009 07:52 PM
