s2 backfires when turn engine off
Old Oct 4, 2009 | 04:43 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
Default s2 backfires when turn engine off
as above my s2 has developed a backfire when i turn the engine off.
running rich?
Old Oct 4, 2009 | 04:51 PM
andy130's Avatar
andy130
could be over fueling mate
Old Oct 4, 2009 | 04:59 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
it seems ok when drivin it, just when i turn it off. gettin it set up by harvey gibbs next week hopefully
Old Oct 4, 2009 | 05:02 PM
orionmojo's Avatar
orionmojo
mine pops on cold startup... Go figure!
also it sometimes pops when its turned off, but its only done both since it was setup at nms. it runs fine, and sometimes pops on gearchange too, which i love.
Old Oct 4, 2009 | 06:03 PM
rstdave's Avatar
rstdave
Mine used to do this when it was on mfi....if i'd been driving it hard it would backfire pretty loud when i turned it off! No longer does it now it's on efi, think it must be the mfi chucking too much fuel in, nothing to worry about.
Old Oct 4, 2009 | 07:21 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yup MFI overfuels like mad any time other than full load WOT or idle.
Old Oct 5, 2009 | 04:55 PM
mr_joe0606's Avatar
mr_joe0606
mine does the same when i turn it off give it a couple secods a little pop. but when you let it cool down 4 like 2 mins or over it does not happen. just lettin me no its still there lol
Old Oct 5, 2009 | 09:23 PM
Red_bull's Avatar
Red_bull
mine does it to, but i'm going for a set up when i got my new radiator, so maybe there will be a change
Old Oct 5, 2009 | 11:01 PM
RSTurboSI's Avatar
RSTurboSI
Mine Bangs all the time, Off boost on slow down normaly, sometimes on cool down it does pop also, and when turn off it also backfires, buts its over fueling anyways
Old Oct 5, 2009 | 11:25 PM
Chopshop85's Avatar
Chopshop85
Its a classic mfi trait I think.. especially if youve been for a blast. Mine does it about 10-15 seconds after ive got out and locked the door sometimes lol. Always has done, even after various parts and several tune ups in its life time.
Old Oct 9, 2009 | 01:18 PM
mk1trb's Avatar
mk1trb
Boost Junkie
think its jus too much fuel on idle in a hot engine and exhaust, nearly all my rs' do it
Old Oct 9, 2009 | 01:29 PM
MunkeyboyRS's Avatar
MunkeyboyRS
Bananas!
My rs very rarely pops or bangs loudy, and even more rarely spits flames out, now mate one is like a flame thrower! is down to my shit exhaust?
Old Oct 9, 2009 | 02:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
No it's beacuse yours is leaner than his, nothing to do with the exhaust mate.
Old Oct 9, 2009 | 02:51 PM
NEILNATO's Avatar
NEILNATO
SCOOBY DOOBY DON'T!!!
I came across this prob with mfi, what i found out is the 5th (cold start) injector was dribbleing fuel due to the pressure in the system, which is still there after you switch the engine off, so the fuel vapour finds its way into the hot exhaust manifold and det's making the pop you hear, change the injector (for those who dont know, its the one under the inlet manifold) and it will remody the pop.
Old Oct 9, 2009 | 02:59 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Unlikely, but it would be the cause of rich running in general
Old Oct 9, 2009 | 03:00 PM
MunkeyboyRS
Bananas!
ahh cheers dude, I had been wondering, as I did think my car should be running rich as i changed the metering unit and i was told by my mate it was running rick on his car, and i'd just been lazy and not re set it, but couldn't help thing why wasn't in not popping more at the same time.
Old Oct 9, 2009 | 03:05 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If you've changed the metering unit go and get it set up on a RR or your risking you engine mate, specially as it appears you are a little lean!!
Old Oct 9, 2009 | 08:17 PM
MunkeyboyRS
Bananas!
What probs can it lead to? its been like that for about 3 weeks
Old Oct 9, 2009 | 10:21 PM
botters's Avatar
botters
competant bodger
if lean melted pistons for starters! if too rich you get bore wash which can cause unburnt fuel to seep past the rings into your sump degrading the oil and shafting yer crank! i found this out the hard way!
Old Oct 9, 2009 | 11:47 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Exactly! Get it setup mate, really important!!
Old Oct 9, 2009 | 11:52 PM
DazC's Avatar
DazC
this is also a symptom of running lean believe it or not.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
The Underdog
29
Sep 7, 2015 09:49 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
