Rs Turbo Clutch, How long does it last?
Old Oct 4, 2009 | 02:34 PM
RST's Avatar
RST
Default Rs Turbo Clutch, How long does it last?
As above. Fitted Ap 4 padle with standard pressure plate. about 2000 miles ago, and last night it started slipping. It feels like the pressure plate cant hold it. Anyone else had the same problem?
Cheers Jaiz
Old Oct 4, 2009 | 02:52 PM
LHD220Turbo's Avatar
LHD220Turbo
did you skim the flywheel before fitting the new clutch?
Old Oct 4, 2009 | 02:57 PM
obrutsr09's Avatar
obrutsr09
done 8000miles no problums
Old Oct 4, 2009 | 03:06 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Shouldn't be going after 2k, flywheel as mentioned could be why. My old ZVH ate a brand new standard clutch and gearbox in under 5k. What torque you running?
Old Oct 4, 2009 | 03:11 PM
RST's Avatar
RST
Yes the flywheel was skimmed. 192Ft torque.
Old Oct 4, 2009 | 03:21 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
A clutch should last for a long time if it doesnt slip/isn't slipped!
Old Oct 4, 2009 | 04:05 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
See, I've been here before. The AP Paddle plate wasn't designed to be used with a standard cover. Thats why. It needs a certain amount of clamping force, if you haven't got that it will slip. A cerametallic clutch slipping won't last long atall.
You'll probably have a knackered flywheel too now.
Old Oct 4, 2009 | 04:08 PM
andy130's Avatar
andy130
as above
ap says u need there cover for that clutch mate
neil18
Mar 14, 2016 01:08 PM
Matt Baxter
Sep 16, 2015 08:30 PM
paceo
Aug 27, 2015 12:45 PM
Toe Knee
Aug 23, 2015 08:31 AM
Billy_RS
Aug 3, 2015 08:43 PM
