does stone chip stop rust?
Old Oct 4, 2009 | 12:17 PM
andy130's Avatar
andy130
Default does stone chip stop rust?
as above iv seen ppl putting it on there cars but i think its a waste of time cause all ppl do is clean the floor with thinners the slap the stuff on which in my eyes is pointless like whats it going to stick to? and it doesnt bonded as good as primer would,justlike to see if you think it stops rust? thanks
Old Oct 4, 2009 | 12:22 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Often it can make things worse, as if the seal gets broken it can hold water right next to the metal and encourage rust.
Waxoyl is a better option IME
Old Oct 4, 2009 | 12:24 PM
andy130's Avatar
andy130
thats what am thinking cause if theres rust under the ford sealer and u put stone chipover it thers not a cause you'll see it which may lead to a rot floor
Old Oct 4, 2009 | 12:27 PM
jammerrs's Avatar
jammerrs
what does a painted floor do then?
or do people still use a rust protection under the paint?
Old Oct 4, 2009 | 12:54 PM
Paul_RS's Avatar
Paul_RS
Its just like the painted top of your car? If its painted onto a non rusty base, its fine
In my opinion to do the underside correctly, you need to take it to bare metal, prime, then stonechip, then paint, then waxoil if required. Should leave you with a really well protected floor
Old Oct 4, 2009 | 01:04 PM
hughy's Avatar
hughy
yea i wish i never stonechipped my ecos now should of done it with a primer the same color as the org floor was then waxoiled it
Old Oct 4, 2009 | 01:28 PM
andy130's Avatar
andy130
but sure whats the point in that? you would be better off just putting wax oil on it!
Old Oct 4, 2009 | 01:45 PM
focus st2's Avatar
focus st2
If the floor is prepared properly it would help prevent rust. Waxoil afterwards and should be fine
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
