L6???
Old Oct 4, 2009 | 02:58 AM
airbrushfx's Avatar
airbrushfx
Default L6???
can anyone tell me if this http://cgi.ebay.co.uk/ws/eBayISAPI.d...tchlink:top:en would be suitable for my rs2000 i4 16v turbo build? would the injectors fit in the stock fuel rail? management side, would i need anything else if this is suitable?
Old Oct 4, 2009 | 11:28 AM
airbrushfx's Avatar
airbrushfx
anyone?
Old Oct 4, 2009 | 03:38 PM
It will do the job, I would imagine your injectors are top fed bosch that look the same as these ones ?.
The only thing that immediately springs to mind is the ignition, yours is coilpack, this will NOT operate a coilpack as std, but can be converted, yours also may use a MAF, if so this can be junked and use the map sensor instead, may well need to install a air temp sensor though.
tbh, it could be made to work, but not worth it, by the time you had it converted to work coilpack, then the other bits, you might as well for the price get a aftermarket one.
Old Oct 4, 2009 | 03:43 PM
Paul_RS's Avatar
Paul_RS
RS 2000 uses side feed injectors, so thats the first hassle. I think they are the wrong impedance for the cossie ECU, could be wrong there though!
RS 2000 has no MAF, it uses a MAP sensor and has an air temp sensor too
Old Oct 4, 2009 | 03:50 PM
Paul_RS's Avatar
Paul_RS
Just metered my old RS 2000 injectors and some spare 803s i have
2000 ones are 14 ohms, Cossies ones are 4 ohms, so i think you'll have issues running the standard ones if you use cossie management?
Old Oct 4, 2009 | 04:01 PM
J1mbo's Avatar
J1mbo
B1mbo
could put it on pectel management with the standard high impedance injectors
Old Oct 4, 2009 | 04:09 PM
airbrushfx's Avatar
airbrushfx
ok, well sounds a bit complex for a simple paint sprayer like myself lol
my other option is http://www.mtechautomotive.com/Ford.html
is this really just plug n play & live mapping? would i need a wideband o2 sensor to run this? as you can tell i'm lost on the management side of things
Old Oct 4, 2009 | 04:17 PM
J1mbo's Avatar
J1mbo
B1mbo
for mapping you need a good lamnda sensor so you can see what air fuel ratio you have
Old Oct 4, 2009 | 04:20 PM
airbrushfx's Avatar
airbrushfx
cool cheers, i think i'll go down the v3 p n p route and get a lambda sensor seems the best route for me i think
Old Oct 4, 2009 | 04:22 PM
J1mbo's Avatar
J1mbo
B1mbo
also airbrushfx, is that your company, ive heard of something similar round my way, peterborough, are you any where round here ?
random one i know lol
Old Oct 4, 2009 | 06:53 PM
airbrushfx's Avatar
airbrushfx
nah mate i'm in brighton, i haven't traded under that name for a few years now just never got round to changing it! my business is air-kandi but i sign air-devil if that helps
Old Oct 4, 2009 | 06:56 PM
J1mbo's Avatar
J1mbo
B1mbo
ah right just thought id heard of it before, obviously not lol
