Spark plug gap!?
Old Oct 3, 2009 | 04:33 PM
mpf1987's Avatar
mpf1987
BOOOOSSSST
Lightbulb Spark plug gap!?
Can some one please tell me the plug gaps for a S2? will they differ the more bhp you run? and what are a good make of plug the 1's out are Champion. Cheers
Old Oct 3, 2009 | 05:06 PM
mpf1987's Avatar
mpf1987
BOOOOSSSST
Anybody!!!!
Old Oct 3, 2009 | 05:24 PM
071's are a good plug, and these are used on the cossie as well, I think they're std fit on the rst's ?
I wouldn't widen the gap, as this can promote misfires if coil is not very good.
Wider gaps actually came about for lean burn engines.
Old Oct 4, 2009 | 09:00 AM
mpf1987's Avatar
mpf1987
BOOOOSSSST
What should the gap be tho? just so i can check wen i buy some.
Old Oct 4, 2009 | 09:05 AM
mpf1987's Avatar
mpf1987
BOOOOSSSST
Will i get these from ford?
Old Oct 4, 2009 | 01:16 PM
Chris Latham's Avatar
Chris Latham
Parts Restoring Nutter
Hi matey
I would go for the NGK BCR8ES spark plugs set at 0.8mm gap.
Highly recommended for the RST as well as the 071's
cheeRS
Chris
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Oct 23, 2015 07:54 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
