Hearts and Diamonds ecu
Old Oct 3, 2009 | 12:39 PM
nealo's Avatar
nealo
Focus WRC
Default Hearts and Diamonds ecu
hey,
can anybody shed some light on these? are they from ford or what?
Old Oct 3, 2009 | 12:44 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
yes. it's a long time since i had an rst but they are the 90 spec s2 ones iirc.
or at least the newest available.
Old Oct 3, 2009 | 12:46 PM
nealo's Avatar
nealo
Focus WRC
are they just a standard mfi computer but it allows you to run 1 bar of boost standard??
Old Oct 3, 2009 | 12:48 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
there is a boost limit there but it's easily removed. I'm sorry i cant remember the ins and outs of how to do it as it was 10 years ago
Old Oct 3, 2009 | 12:51 PM
nealo's Avatar
nealo
Focus WRC
i was under the impression it ran a bar of boost standard
Old Oct 3, 2009 | 12:53 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
No Mate.
Standard rst is 7psi i think?
Before i had mine modded i had mine running 10.5 psi i think it was. Steven RW did it for me so hopefully he'll pop in here
Old Oct 3, 2009 | 12:54 PM
Matt carter's Avatar
Matt carter
1/2 bar standard
In answer to your question, a hearts and diamonds ecu is the main ecu found on late spec escort rs turbos.....if you look on the front of it, it will have hearts and diamonds pictured on it..earlier ones have different coloured square blocks on it insted. If I remember rightly, the hearts and diamonds ecu's cost more to chip...altho I dont know why, a software issue of some sort.
Old Oct 3, 2009 | 01:08 PM
nealo's Avatar
nealo
Focus WRC
Originally Posted by Matt carter
1/2 bar standard
so basically having a hearts and diamonds ecu is no different to having the normal ecu and it runs no extra boost as standard?
cheers
Old Oct 3, 2009 | 01:11 PM
S1 Combi's Avatar
S1 Combi
My mate recently gave me a chipped hearts and diamonds to try on my van as was havin some fueling probs,it really didnt like it though and the power graph looked like the swiss mountains
Old Oct 3, 2009 | 01:20 PM
Matt carter
cheers
Thats right.
What is the spec of your engine ?
Old Oct 3, 2009 | 01:24 PM
nealo's Avatar
nealo
Focus WRC
that could be purely down to the chip thats been put on it though mate.
Old Oct 3, 2009 | 03:37 PM
sm's Avatar
sm
dont quote me on this but im pretty sure this is correct if not someone will correct me where im wrong
here are the different type of erst ecus
s1 blue red blue no knock sensor
early s2 blue red white no knock sensor
s2 blue red black knock sensor
s2 hearts diamond hash knock sensor
all the ecus bar the hearts diamond hash are 7 psi from the factory but can go to 8-9 before overboost cuts in
hearts diamond hash ecu are 8 psi as std but can go to 10-10.5 psi before overboost cuts in
if u use a knock sensor ecu on a car without a knock sensor within the wiring loom then u will have probs as the ecu wont be recieving a signal from the knock sensor so the ecu thinks there is a problem as there is a break in the circuit
so basicly if u have a car with no knock sensor in the loom then u can use the s1 ecu or the early s2 ecu
if u have a car with the knock sensor wiring in the loom then u can use the s2 blue red black or the hearts diamond hash ecu
as for chips all they basicly do is just remove the boost limit thats it apart from the turbosystems chps as they also do something else but i couldnt tell u what
Old Oct 3, 2009 | 04:21 PM
S1 Combi's Avatar
S1 Combi
That'll be why mine didnt like the hearts and diamond then
Old Oct 3, 2009 | 06:08 PM
Some top info here.I will try and remember it.
Old Oct 4, 2009 | 04:18 PM
nealo's Avatar
nealo
Focus WRC
sounds good so i was right in thinking the hearts and diamonds allows a higher boost limit.
Old Oct 4, 2009 | 08:23 PM
milesy23rst's Avatar
milesy23rst
PUG 306 GTI-6
You can run up to 10.2 psi on a hearts and diamonds ecu without a chip, and ahmed bayjoo chips as well as turbo systems remove the boost limit and do something to the ignition but cant be 100% certain
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
