now got smoke coming out of the breather!
whar causes this? the water level is ok it had a new bottom end top end skinned new gasket ect,thanks andy
Go give it a good blow out mate and see if that clears it- has your car previously had a head gasket failure with the same breather setup and pipes?
could be a case of clearing it all out- you'll want to do another oil change aswell if thats the case.
james it got a ford breather, its got a new fia gasket on it?
xr2wishy
no the car hasnt done a full mile snice rebuild?
Chris69
no the car hasnt had a head gasket failure?
yes it got the same breather setup
now its got smoke coming out of the breather? but only once u rev it? am getting pissed off with this so pls help
xr2wishy
Chris69
