ST170 suspension
Old Oct 1, 2009 | 05:25 PM
juni0r's Avatar
juni0r
Default ST170 suspension
What are the differences between ST and normal 2.0 suspension.
I have cheapy coilovers and the front wont fit in the lower mounting points.
is there a difference in size shocks??
this area
Old Oct 1, 2009 | 06:11 PM
bazzle's Avatar
bazzle
pretty sure they are the same fella
Old Oct 2, 2009 | 11:37 AM
Sp3no's Avatar
Sp3no
Should fit fine
Old Oct 3, 2009 | 10:09 AM
phil_focus's Avatar
phil_focus
hi sam, i see you've come here for info too
i've always thought they were the same, i recon its the cheapy suspension mate
Old Oct 3, 2009 | 06:37 PM
focusv8's Avatar
focusv8
Standard and ST are the same.
RS uses a bigger diameter shock.
Your problem looks to be the chrome, it's mad the diameter slightly larger,
You would normally have to open up the socket on the knuckle with a wedge to get the shock into the hole.
I'd sure there is a Ford special tool, but a steel wedge or large screwdriver knocked in the gap usually opens it up.
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
