mondeo tdci wont start on cranking
Old Sep 29, 2009 | 11:35 PM
mactheknife's Avatar
mactheknife
Default mondeo tdci wont start on cranking
just sold a mondeo tdci on a 03 plate to my uncle, (big mistake) he had it 2 weeks now it wont start. only way to get it going is to spray easy start down intake. soon as u switch off wont start again. changed crankshaft sensor , injector rail& sensor , pump sensors , fuel filter , been told to check timing chain hasn jumped a tooth or 2.?? once started with easy start , seems to tickover for ever, but take it 4 a run & it will just cut out??. n e suggestions? running out a ideas. help!!
Old Sep 30, 2009 | 02:50 PM
Have a look to see if it is dragging air in the fuel system anywhere.
Old Oct 1, 2009 | 05:11 PM
mactheknife
Hi . thanks for your reply, have already tried that, used a remote fuel supply. this ones really doing ma head in!! any more ideas??
Old Oct 1, 2009 | 07:26 PM
Alvyn's Avatar
Alvyn
knackered injectors m8!
Alun Gregory
Sep 6, 2015 09:40 AM
Zoggon
Aug 10, 2015 10:39 AM
