Cosworth Parts Turbo Technics T38 and loads more
I only post items via DHL due to having a few issues with Royal Mail, so you'll get a tracking number once they are picked up. All items are insured upto £50 included in the postage price I can increase insurance cover at cost if you like. (Minimum postage charge is £8, DHL prices not mine)You can pay by paypal but you must send it as a gift so I don't get any charges. Cheques also accepted will only post once they have cleared. Ideally cash on collection is prefered i'm in Solihull near Birmingham.
Turbo Technics T38
360 Bearing, Turbo technics T38 so it's got the T4 compressor housing and 0.63 turbine housing done less than 3000 miles in very good condition with -34 actuator no play in shaft.
£700 Postage = £25
K & N Grp A Air Filter with SFS Hose and Mikalor Clamp
Air filter is abit grubby but in good condition. Fits T38 or T4 Turbo.
£100 Postage = £10
2WD Manifold
Very good condition including both parts no cracks anywhere.
£65 Postage = £25
2WD Sump
Has had 2 repairs can be seen in photos i've had it acid dipped so its very clean.
£40 Postage = £20
3 Door Rear Light Clusters and Bulb holders
Not in the best of conditon no scratches to lenses but have gone alittle bit green under the lense someone at some point has drilled very small hoses at the bottom of the lense to let water out i'd imagine on both left and right sides both bottom bolts have been snapped off.
£20 Postage = £15
Genuine Ford 3 Door Rear Light Foam Gasket Seals
Although genuine ford they are not as thick as standard ones for some reason
£25 Postage = £8
Mongoose 3" Down Pipe
Has had a Lambda Boss welded in not the tidyest of welds but doesn't leak.
£50 Postage = Will have to check due to length
Standard Cosworth Fuel Pump
Was working fine when it came off my 3 Door to be replaced by a 044.
£30 Postage £8
Cosworth 4x4 Rear Brakes including carriers
Have been stripped down for reconditoning comes with new Bigg Red seal kit.
£40 Sold to RUBY123
Sapphire Cosworth Rev Counter
Mint condtion working perfectly
£40 Postage = £8
Sapphire Cosworth Front Hubs
Bare hubs powder coated blue
£20Sold to RUBY123
-34 Actuator
One of those after market jobbies never fitted it so no idea what psi it's set to.
£20 Posatge = £8
SFS Turbo to Air Filter Hose
£20 Postage = £8
Roose Motorsport T3/T34 Turbo to Intercooler Hose
£20 Sold to florent78
Samco T3 Turbo to Air Filter Hose
£20 Postage = £8
Samco T3/T34 Turbo to Intercooler Hose
Has been slightly trimmed at intercooler end
£20 Postage = £8
Roose Motorsport GT30/GT35 Turbo to 3" Intercooler Hose
Has been trimmed at turbo end (suits a 4x4)
£35 Postage = £8
Samco Intercooler to Throttle Body with DV take off 2.5" both ends
£25 Postage = £8
909 Motorsport Turbo to Intercooler Hose
Very slight trim to turbo end (5mm)
£20 Postage = £8
SFS GT30/GT35 Turbo to Air Filter 102mm
Brand New never fitted
£40 Sold to RWD cossie will
Cheers Rich
Turbo Technics T38
£700 Postage = £25
£100 Postage = £10
2WD Manifold
£65 Postage = £25
2WD Sump
£40 Postage = £20
£20 Postage = £15
£25 Postage = £8
£30 Postage £8
£40 Sold to RUBY123
£40 Postage = £8
£20Sold to RUBY123
-34 Actuator
£20 Posatge = £8
£20 Postage = £8
£20 Postage = £8
£20 Postage = £8
£35 Postage = £8
£25 Postage = £8
£20 Postage = £8
Cheers Rich
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
muz
Aug 16, 2015 12:57 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
