efi idle problem
Old Sep 28, 2009 | 09:14 PM
paul66 turbo's Avatar
paul66 turbo
Default efi idle problem
hi all ive got a problem with my s2 its running ofab efi
when i conect up the iscv the revs rise to around 3k for a few seconds then settle to 1k but every time you touch the throttle it happens again, with the iscv disconected all is ok the idle is fine and revs ok have tryed a different iscv but still the same was ok when running ofac
was ok running ofac then changed these parts to run ofab
ecu ofab with 165 chip
ofab map sensor
inlet manifold (was powder coated)
throttle body
beige injectors
any ideas please
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
RSmark84
Sep 13, 2015 01:29 PM
dms04
Sep 11, 2015 01:57 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
routemaster
Sep 7, 2015 05:27 PM
