8" incher
hi, hope you didnt click this for another reason....
but is anyone running 17x8 alloys. i have a s1 and have found some nice wheel but im worried they are going to be too wide and foul on everything.
any advice would be great ta
Mate, 7.5 inch alloys on rs turbos rub, so I would completely advise against putting on 8 inch ones. Would be scraping and bumping like a bitch. It is usually the insides of the arches are the ones that rub.
They may be ok if you run a 205 tyre or 215 and trim the arches back a bit
Well my rs and a couple of my mates have rubbed with 7.5. It is usually only on full lock they foul
i had 8" on and they didnt rub.the only thing they caught was the coilovers by about 1mm.its all about the offset mate.they can fit and you dont need loads of arch work as my s1 had none and they were on no problem.
frenchy
18
Jun 8, 2011 10:00 AM
