cosworth 2wd loom and ecu
i have a standard tidy loom and ecu (unchipped) that i removed from my 1990 2wd sapphire cosworth.no broken wires or repairs to the loom and was all working perfect when i removed it from my car.the temp sensor rubber plug has came off but i bared a small part of the wire back and twisted it round the temp sensor then pushed the rubber plug over it and that worked perfect.comes with nearly new crank position sensor,coolant sensor and boost pressure sensor.£145 delivered.ta,lee
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
