best sparkplugs for s2 rst???
Dec 22, 2004 | 03:41 PM
wots the bestsparkplugs 2 use on standard rst????
Dec 22, 2004 | 03:49 PM
I think up to around 200hp ford PP8's are very good, after that i have no idea
Dec 22, 2004 | 04:03 PM
i have always thought that splitfire platinums were good plugs i use them in my rs2k, dont know how they perform in a s2 though?
Dec 22, 2004 | 05:11 PM
Dec 22, 2004 | 08:05 PM
champions are good but dont last long , they are a very cheap plug though
Dec 22, 2004 | 08:40 PM
champions are £30 a set! thats aint cheap!
I use NGK's in mine doin over 200bhp its fine and they are cheap!
Dec 23, 2004 | 12:55 PM
wots the difference between the iridium tipped and platinum tipped which ones better, cum on must be sum spark plug experts out their!!! cheers 4 ur replys guys
Dec 23, 2004 | 01:49 PM
NGK bcr8es are good plugs.
Dec 23, 2004 | 02:19 PM
Use the Ford Motorcraft jobbies on a standard rst
Dec 23, 2004 | 02:20 PM
Do jobbies spark?!! lol.
Dec 23, 2004 | 02:23 PM
Sorry.
Use the standard ford motorcraft spark plugs that are recommended for the rst
Dec 23, 2004 | 04:32 PM
finis number 1120834, these are the 071C plugs which are suitable for high bhp cossies as well !
BCR8ES is a good plug as well, if your running high boost I would steer clear of these though............or change them regularly.
Duncan
Dec 23, 2004 | 06:04 PM
Can I ask why you have suggested plugs for high bhp cossies when the guys has aksed for plugs for a
standard bhp rst
Dec 23, 2004 | 06:10 PM
i use Bc8res too, wldnt use em for a fast rst tho im told.
Dec 23, 2004 | 06:33 PM
Quote:
Can I ask why you have suggested plugs for high bhp cossies when the guys has aksed for plugs for a standard bhp rst
because there listed as standard rst plugs
Dec 23, 2004 | 06:45 PM
I use the NGKs was recommended by my mate and Power engineering. Champion are no good.
Dec 23, 2004 | 07:15 PM
well I didn't know that!
ok mate
Dec 23, 2004 | 09:53 PM
NGK's do it for me. dont entertain champion
Dec 23, 2004 | 10:05 PM
Dec 23, 2004 | 10:10 PM
Went to rolling road and they threw the Champion plugs out and replaced with the NGK's. Got better results with the NGK's.
Dec 23, 2004 | 11:09 PM
Dec 23, 2004 | 11:50 PM
Im using BCR8ES and they are fine in my car
Dec 24, 2004 | 09:16 AM
I bet the guy's well confused now.
what a lot of old crap im reading on here
Dec 24, 2004 | 09:55 AM
second that
Dec 24, 2004 | 10:00 AM
dont you just know it !
At the end of the day speak to your tuner and see what he reccomends. If not, it dont really matter that much as you say its only standard, go into your local motor factors and see what they stock, will probably be the NGK's which in my opinion is the best plug for a standard rst.......or the ford ones, its up to you.
Duncan
Dec 24, 2004 | 11:02 PM
RITE GNA START A NEW TOPIC IL TRY 2 BE MORE PRECISE!!!
Dec 25, 2004 | 12:11 PM
Jan 26, 2005 | 03:29 PM
Duncan
just ordered these from fords for £2.39 each
hope there ok on my car
Jan 26, 2005 | 04:51 PM
they will be mate, I've run these up to 26psi and never had any problems
Duncan
Jan 26, 2005 | 10:52 PM
just got a deal... 12 701c for a tenna... i love e bay..
Jan 27, 2005 | 08:09 AM
071s have always been good to me.
Jan 27, 2005 | 08:40 AM
bargain mate
Jan 28, 2005 | 06:15 PM
bargain mate
i just got mine for £2.30 each from ford
not tried yet but will do tomorow
whats the best gap for them u lot reckon
Jan 28, 2005 | 09:23 PM
Quote:
i just got mine for £2.30 each from ford not tried yet but will do tomorow
you got the 071's didnt you
The 701's are no longer available from ford, although they are the same spec plug they are supposed to be better than the 071 for some reason, I think I read somewhere that they were the WRC plugs, dont hold me to that though
Regarding the gap, depends what spec engine you have ! I believe the standard gap is 0.8mm but I was advised by stu at msd to gap my plugs to 0.7mm because of my stage 3 head & turbo, something to do with the increased airflow
Try pm'ing him, see what he suggests
Duncan
Jan 29, 2005 | 09:02 AM
Jan 30, 2005 | 02:22 PM
Which NGK`s ?? got to change mine soon , and was gonna put c59`s back in them ?? HELP!!! 16psi
Jan 30, 2005 | 02:29 PM
Just bought a set of NGK BCR8ES
Hope there good , got 4 for a fiver
Jan 30, 2005 | 06:47 PM
Feb 6, 2005 | 05:11 PM
got a set of 701c e-bay if anyones interested....
Feb 7, 2005 | 11:21 AM
PMSL i cant believe people are using £5 spark plugs in tuned RST's
