no battery or oil warning light
Old Sep 20, 2009 | 08:50 PM
DANIEL p's Avatar
DANIEL p
LOVE FORDS
Default no battery or oil warning light
i recently put new engine in my s2 and when i turn ignition on i have no battery warning light or oil warning light i no the alternater is good as it was on my old engine and worked fine i also no the bulbs in dash are good any ideas pls
Old Sep 21, 2009 | 10:11 AM
Both these relay on earth return to light the bulbs, so I would check the earth strap first is fitted tightly, then earth the thin blue wire out on metal/engine to see if bulb works, and same for the oil pressure wire.
StephTell
Sep 2, 2015 06:31 PM
dojj
15
Aug 18, 2015 08:21 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
Neatrags
Aug 16, 2015 07:57 PM
