Starting Trouble
Apologies for my first post being a cry for help, but i'm sure someone on here will be able to help me.
I've got a S2 RS Turbo that i'm having starting problems with. It's fine in the mornings, or when it's been left for a while, but if I go somewhere and leave the car for just a few minutes then try and start it again, it won't work for about 5 minutes (which can be quite annoying at the petrol garage). I've replaced the starter motor twice, which seemed to sort the problem for a week or 2, but after that the problem was back again. Any ideas?
http://cgi.ebay.co.uk/HEAT-WRAP-TAPE...d=p3286.c0.m14
and you'll need some st/st cable ties
http://cgi.ebay.co.uk/8-STAINLESS-ST...d=p3286.c0.m14
Had the same problem with mine starter motor turns over very slow when the car is hot had a new starter motor all was fine then same again so i changed the battery loom alls working fine now,the wiring goes all brittle with being so close to the down pipe after 20 years of use they where due for a change
We had the same problem on our old series 2 would drive 5 min turn it off then it wouldn’t start straight away turned out to be the Fuel pump relay bought a new one fitted it and it was fine after
Brian
Brian
