Should i be able to move actuator rod myself?
Old Sep 19, 2009 | 07:59 PM
Lincolndanny's Avatar
Lincolndanny
Default Should i be able to move actuator rod myself?
Hi guys, got my Bonus Turbo up and running but getting naff all boost. Amal valve is working, all pipes etc are fine.
Popped my head under the old girl and i can pull the actutor rod out easily. I take it this may be my problem? Standard actutor by the way!
Regards
Danny
Old Sep 19, 2009 | 08:26 PM
stevenebm's Avatar
stevenebm
post whore
i wouldnt think you should be able to move it as it should be on tension by a spring?no expert mate but id think it was that.
Old Sep 19, 2009 | 08:59 PM
RAT8OY's Avatar
RAT8OY
No you shouldnt be able to move it easily by hand! Your actuator has gon soft meaning it will not allow the turbo to make any boost.
The actuator holds the wastegate closed until enough boost pressure is made at which point the positive air (Boost)in the vacum pipe to the actuator over comes the tension of the spring in the actuator pushing the rod and opening the wastegate which directs the exhaust gasses away from the exhaust impeller slowing the turbo.
When the spring is old and goes soft lossing its tension this mean the positive air can overcome the spring very easily thus openeing the wastegate long before you want it to.
Old Sep 19, 2009 | 10:06 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
get a new actuator. end of.
boeb
Jan 9, 2020 05:11 AM
tankybaby66
Feb 6, 2016 02:24 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
little bram
Sep 27, 2015 07:45 AM
