Looks like my spare box needs a little more attention than i'd hoped....
Old Sep 19, 2009 | 10:36 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Default Looks like my spare box needs a little more attention than i'd hoped....
............. one of these missing teeth was jaming the selecta mechanism which is why I only had 1st and 2nd when it died
Not sure what the best plan is now really, find a good second hand box, get new parts for this one, etc..??
Old Sep 19, 2009 | 10:39 AM
m4tt274's Avatar
m4tt274
NICE! lol
Old Sep 19, 2009 | 10:59 AM
Tim's Avatar
Tim
what parts do you need as i have 1 in bits with good gears etc
Old Sep 19, 2009 | 11:00 AM
RSandy's Avatar
RSandy
id just get a good second hand lower spec box, rob it if its gearset (assuming your not desperate to retain the exact rs turbo ratios), and then throw it together with your RST LSD, and with a new bearing kit which im again assuming u already have if you were sprucing up the box anyways
Old Sep 19, 2009 | 11:04 AM
white2lsr's Avatar
white2lsr
If you have gone this far then i would get the new parts you require and fix it. At least then you would know the box was good.
Old Sep 19, 2009 | 11:08 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Originally Posted by m4tt274
NICE! lol
lol
Cheers! So far just the input shaft pictured, pm me a price posted mate
I'll take a closer look at the rest and see if there is anything else I might need!
Not a bad plan, I have not bought the bearing/seal kit yet was waiting to get this apart and see what it needed.
Old Sep 19, 2009 | 11:11 AM
crazycage's Avatar
crazycage
i would look into a mtx conversion or you will doing this again soon lol.
Old Sep 19, 2009 | 11:12 AM
RSandy's Avatar
RSandy
thats what i did with mine anyways, as my RS box mainshaft was worn beyond belief
so ran home, grabbed the decent spare boggo box i had, had that stripped and inspected, robbed it of its fullg earset and bolted it all into the rs casing with the LSD and a new bearing set
basically my rebuild cost me 200quid all in, with paying him to strip 2 boxes. but it was cheaper than buying another rs box, still with the risk that it might be a dud, and then just having piles and piles of worn rs gearsets
the gear ratio issue wasnt of any concern to me though, nor is my spec as big as yours
Old Sep 19, 2009 | 11:13 AM
Karlos G's Avatar
Karlos G
Balls Deep!
I'd love to but i'm not competent enough with fabricating to do the conversion myself, I understand there is a fair bit of hacking and welding of the inner wings etc..
Old Sep 19, 2009 | 11:19 AM
crazycage's Avatar
crazycage
yes you do have mod the inner wing but thats the easy bit lol but if you cant weld it would cost a fortune to get it done.
Old Sep 19, 2009 | 11:21 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah my welding skills are basic at best
Old Sep 19, 2009 | 12:25 PM
Karlos G's Avatar
Karlos G
Balls Deep!
The rest of the box looks alright, although it is one of the earlier small bearing box's so i'm going to have to have it machined out to accept the later bigger bearing or the rebuild is pointless
In the above picture.....
The cog up from bottom.... teeth look worn to me but i'm not sure if they are sposed to be like that?! lol
Old Sep 19, 2009 | 12:48 PM
CF20's Avatar
CF20
RS
just use a early type ib5 box from a mk 5/6 escort they have the bigger bearings and the starter at the front then fit the lsd from your box
Old Sep 19, 2009 | 03:09 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah but then i'm running old bearings etc... may as well do this box up for about £150 and know it's all good.............
Old Sep 19, 2009 | 04:15 PM
studabear's Avatar
studabear
from what I read on jano's site theres 1 bit which needs cutting out and then plating as far as getting the box into the bay that is,
Are the mtx boxes that tough?
Old Sep 19, 2009 | 04:56 PM
crazycage's Avatar
crazycage
ive gave mine death on a 300bhp fezz for the last 6 months and over 20 runs at the pod so yes much stronger.
boeb
Jan 9, 2020 05:11 AM
mjonathan24
Oct 29, 2015 10:39 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Steve Escos
Oct 1, 2015 06:57 AM
Russ Payne
Sep 25, 2015 08:29 PM
