Brake lines
Old Sep 18, 2009 | 08:35 AM
white2lsr's Avatar
white2lsr
Default Brake lines
If you ignore the ABS on a turbo, are the brake lines from master cylinder to back axle the same on a mk 3 and mk 4 escort? I need some brake lines made up and could do with some origional ones to copy as it would make things a lot easyer. I have removed my ABS and there are some mk3 escorts in the scrappy so im wondering if I could remove these.
Cheers.
