Fiesta TDci air in fuel
Old Sep 17, 2009 | 05:20 PM
mikeg's Avatar
mikeg
Default Fiesta TDci air in fuel
Could someone advise on cause for air getting into the fuel system which is causing the car not to start, I have to use the fuel primer most days.
Is this a known issue????
Old Sep 17, 2009 | 05:54 PM
gup's Avatar
gup
if its the same engine as the what peugeot have in their 206s , had a common problem that the airbox was rubbing on the fuel pipes and causing them to leak check this first fella
Old Sep 17, 2009 | 06:38 PM
cossieDavedree's Avatar
cossieDavedree
Check the diesel primer seals. Mine went on my fiesta van,
symptons were random misfires on roundabouts, and slight hesitation cut-outs,
and difficulty to start after being left to cool for ages.
also check your diesel filter for water.
Alun Gregory
Sep 6, 2015 09:40 AM
