Trader Parts for Sale. Only Registered PassionFord Traders can sell parts in here. Buy with confidence.
New Ford Cosworth GpA Front Anti Roll bar Mounting brackets
Old Sep 17, 2009 | 01:38 PM
Touring Car Spares's Avatar
Touring Car Spares
Default New Ford Cosworth GpA Front Anti Roll bar Mounting brackets
I recently had to have a pair of these made to replace the cumbersome Alloy X-member thats available to mount Fords Group A Bladed Anti-roll bar kit , so ive had a few more made while i was at it .
Ok the alloy x-member does mean you can jack the car up off it but it also interferes with cables and hoses so these clean up that area and look great when fitted .These are made in steel , laser cut and tig-welded ,aero-tec shakeproof nuts are used to mount the bar and the whole thing can be primed and painted afterwards , you could even drill and bolt these up if you preferred . These are an Honest copy of the original ( you can see the Ford logo on the left hand one ) ,ive fitted several pairs so far with no problems , i can also supply the complete kit !
£100 the pair inc VAT & postage to mainland UK .
Old Sep 17, 2009 | 02:31 PM
Touring Car Spares
Old Sep 25, 2009 | 08:26 PM
Miller 3's Avatar
Miller 3
How much is a complete kit Tony
Old Sep 26, 2009 | 07:11 AM
Touring Car Spares
Bar Tarmac spec 28mm £300 (rear bar is a solid version )
Blades £95 each ,2 needed
Drop links £30 each , 2 needed
Rose joint kit £65 each , 2 needed
Alloy 2 piece brackets £35 each , 2 needed
Nylon bushes £15 each , 2 needed
All plus vat & carriage .
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
martynhomer01
16
Aug 4, 2015 09:55 PM
Old ford
Jul 31, 2015 06:50 AM
