Where can i get the supports which hold the front bumper on at the sides, in behind the wings?
Hi mate,
When I removed the front bumper from my RS the one side had completley rusted through and the other was showing signs of age.
I got my mate to weld two new brackets on that he had made from steel, he copied the one from the side that had not completley rusted through drilled some holes in them and then welded them to the car. Took him about half an hour and thats including making the bracket
All I had to do was primer and paint black, doesn't have to be a mint job because you cant even see them.
Any half decent welder would be able to do this for you
