saff morettes?
Old Dec 21, 2004 | 06:51 PM
cossiedaz's Avatar
cossiedaz
Default saff morettes?
hi all just wonderin who the best supplier of morettes for a saffy is in the uk?
i just bought some about an hour ago, in the dark for a crispy red note.
got em home and felt a bit gutted tbh.
all mounts are broken
all bulbs look like theyve been home made with fibre glass (the 3 mounting studs are fibreglassed onto the bulb)
the worst thing is tho they just dont look right.
any information or advice would be appreciated
thanks
cossiedaz
Old Dec 21, 2004 | 08:44 PM
plater's Avatar
plater
Morrettes come in two pieces, a back section which the bulbs are mounted to and the front twin lamp section which is screwed to the back section. The front part is what you have there, but obviously someone has lost the back parts and has attempted to adapt the fronts by fibreglassing the lamp recess and drilling three holes so that the lenses can be mounted in them. That, combined with the fact that all the mounts are broken renders them pretty useless to be honest, they'll never look right regardless of what you do to them. If i was you i would put them on ebay and try to recoup your money, then buy a new set, morrettes are pretty flimsy and crack easily so i wouldn't bother buying second hand sets unless you've seen them and checked them first.
[img][/img]
Old Dec 22, 2004 | 03:23 PM
CosKev3's Avatar
CosKev3
Think you've bought a set of morette copies there m8
Morette don't use sealed beam lights and as said above they come in 2 pieces.
Old Dec 22, 2004 | 04:12 PM
cossiedaz's Avatar
cossiedaz
cheers guys, wheres the best place to get em from?
Old Dec 22, 2004 | 05:39 PM
JamesH's Avatar
JamesH
Mike Rainbird or Cosssymad IIRC!
Nov 1, 2015 06:53 PM
cossie330
Oct 7, 2015 08:22 PM
Steve Escos
Oct 1, 2015 06:57 AM
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
