Pace charge cooler?
Old Sep 13, 2009 | 02:53 AM
Rob_DOHC's Avatar
Rob_DOHC
Default Pace charge cooler?
Any one have any experiences with these? my intercooler has a pin prick hole from an old shoddy repair and i live in traffic
Rob,
Old Sep 13, 2009 | 04:02 AM
jonny s2's Avatar
jonny s2
id say there wicked in traffic,i had 1 ages ago and worked perfectly but im not sure what they would be like with big power cause i asked this question not long ago and got no real answer,but for around 200hp and to be used in traffic id say they are good
Old Sep 13, 2009 | 07:42 AM
jodyhoare's Avatar
jodyhoare
i have one and they r excellent for everyday use and especially in traffic, i would recomend buddy
Old Sep 13, 2009 | 08:19 AM
Karlos G's Avatar
Karlos G
Balls Deep!
From what i've read (never had one myself) they are good up to the point where the water gets hot and then a FMIC leaves them standing.
Old Sep 13, 2009 | 08:40 AM
jonny s2's Avatar
jonny s2
i think its in the traffic were it runs best,coolers are more for an open road
Old Sep 13, 2009 | 10:53 AM
Rob_DOHC's Avatar
Rob_DOHC
cool thank very much!
I suppose if it runs out of cooling ability a bigger rad and pump would help thing out.
Rob,
Old Sep 13, 2009 | 11:07 AM
jodyhoare's Avatar
jodyhoare
yh i have a bigger rad on mine mate and summer coolant in the system and works excellent
Old Sep 13, 2009 | 11:15 AM
StephenC's Avatar
StephenC
..BS Motorsport..
When I had mine I used the windscreen washer bottle as its reservoir so it had a good few litres of water to play with rather than the pissy little tank that comes with it, then used there tank as my washer bottle. Never had any heat issues after that but I wasnt really running a big spec. (bayjoo chip, cooler, filter and exhaust back then)
Old Sep 13, 2009 | 11:47 AM
T28 RST's Avatar
T28 RST
Ok then
I had one
Even when i added the 2nd water radiator it still couldnt keep the ACT's below 50 deg.
Biggest waste of money i have ever spent on the car.
Old Sep 13, 2009 | 12:00 PM
Rob_DOHC's Avatar
Rob_DOHC
ah..... spanner and works sound right.
bad experience maybe? or all like this. im under 200 brake and have a hole in my inter cooler lol.
Rob,
Old Sep 13, 2009 | 12:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
50deg is terrible!! I dont see above 38deg @ 20psi, 5th gear, WOT, ambient 25deg.
Old Sep 13, 2009 | 12:10 PM
KSA-Cossie's Avatar
KSA-Cossie
Big fmic will be far better.
Old Sep 13, 2009 | 12:14 PM
T28 RST's Avatar
T28 RST
Ok then
Rob,
For the money you will be spending on a intercooler you will get an excellent full front mount intercooler, when you up the power of your car you will need one of these anyway, do it right the first time and save yourself the money.
Old Sep 13, 2009 | 12:15 PM
T28 RST's Avatar
T28 RST
Ok then
Exactly Karlos, i got AVA to make me a an intercooler which never saw above 25deg
Old Sep 13, 2009 | 12:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
25deg!!! Fuck me thats impressive!! Unless it's the middle of winter lol!
Old Sep 13, 2009 | 12:25 PM
T28 RST's Avatar
T28 RST
Ok then
Had the inetercooler for over 4 years, tested in the coldest days and the warmest days.
Old Sep 13, 2009 | 02:11 PM
JamboRS's Avatar
JamboRS
focus rs 1672
that ava cooler was the bollox,retains std boost hoses and fan and has plenty airflow to the rad,plus the fact its single pass with no pressure loss,top cooler,wish id went for one when alan was tryin to blag me one instead of the grs which was a pain to fit and couldnt maintain my boost at high rpm
Old Sep 13, 2009 | 03:07 PM
StephenC's Avatar
StephenC
..BS Motorsport..
does look a decent cooler
Old Sep 13, 2009 | 08:40 PM
martinmilne's Avatar
martinmilne
you say fit a bigger radiator but from wat and how much better is it as i got a alloy rad and i swear it makes it hotter under the bonnet !!!!
Old Sep 13, 2009 | 08:43 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Alloy rads do not cool as well as copper rads
Old Sep 13, 2009 | 08:44 PM
T28 RST's Avatar
T28 RST
Ok then
Hes talking about fitting a bigger radiator to the charge cooler
Old Sep 13, 2009 | 08:59 PM
martinmilne
oh sorry got confused
Old Sep 13, 2009 | 09:00 PM
martinmilne
can you still get new copper rads and where from
Old Sep 13, 2009 | 09:02 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ford, any motorfactors, etc...
Ebay..http://cgi.ebay.co.uk/FORD-ESCORT-MK...d=p3286.c0.m14
Old Sep 13, 2009 | 09:08 PM
martinmilne
cheers karlos just a question but wy are the copper ones better ?
Old Sep 13, 2009 | 09:11 PM
Chris69's Avatar
Chris69
go to any radiator specialist and aslong as your end tanks are ok a recore will cost about £100 - no need to buy a brand new one
Old Sep 13, 2009 | 09:13 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Quite simple really it's just that copper dissipates/transfers heat better than ally! lol
Old Sep 14, 2009 | 01:39 PM
JokerDisco's Avatar
JokerDisco
Rob,
Bought a Pace Charge Cooler a while ago with 2 pre radiators. However I've had bigger cups of coffee than the water tank reservior pace give you.
I've had a 20l tank made up and put in the boot and along with all the pipework I'm hoping that this will see some decent ACT's.
I will let you know how I get on - when I finally get it on the road in the next couple of days.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
The Youth.
Sep 30, 2015 09:59 PM
