Escort cosworth 1992 BT
Hello guys.
The car is now up for sale. If i don't get roughly what i want for it, i may break it.
Ford escort cosworth. 1992 big turbo.
Mallard green
87k miles
7 owners
12 months mot
NO SERVICE HISTORY but loads of receipts/pics of recent bare shell rebuild 2008/09
Engine
Full rebuild low comp engine
All new shells/bearing/ gaskets
High pressure oil pump
Water pump
4 layer WRC h/gasket
ARP stud and nut kit
2wd exhaust manifold
T34.63 turbo with maram 247 shaft (antilag removed, fault with P8)
Scorpion or mongoose exhaust
Cyl head ports, throats opened up
Mountune cams
double valve springs
Piper vernier pulleys
Cambelt and tensioner
Black injectors
Oil cooler
Rs 500 intercooler
023 fuel pump
Bailey oil separater
Mapped by NMS 02/09 (30psi peak tailing to 24psi, 360bhp roughly)
Transmission
Alcon 6 paddle clutch
Reyland hyd conversion
Full spec bara straight cut gearbox (just been rebuilt)
Heavy duty first gear
Heavy duty main shaft
3.9 drop gear set
Taller fifth gear
Vc uprated to 60 nm
Short shift with alloy bushes
Quaife rear diff
Uprated alloy rear diff mount
Quaife front diff
Thick wall casing inc thick bottom plate
(THATS OVER £7000 WORTH OF TRANSMISSION)
Brakes
Standard calipers (all rebuilt)
Mintex race pads
Grooved discs all round
New cooper brake lines throughout
All new ABS sensors
Suspension
Gaz coilovers
Polybushed all over
Interior
Standard in good condition for age of vehicle
New faces for all dials with 2 bar boost dial
Shell
Full respray 2008
Twin headlights
Underside everything painted and very detailed
All new fuel lines
Wheels
Standard escos 16' alloys
4 new dunlop tyres
All new light lenses i.e fogs, inds, rears.
New badges
Its a good all round useable car which has been built to be extremely reliable.
Complete car as listed £16000ono
Car with standard transmission £12000ono
I will not even think about selling transmission until the car is sold.
Dave
Mallard green
87k miles
7 owners
12 months mot
Engine
Water pump
Mountune cams
Black injectors
Oil cooler
Rs 500 intercooler
023 fuel pump
Transmission
3.9 drop gear set
Taller fifth gear
Vc uprated to 60 nm
Quaife rear diff
Quaife front diff
Brakes
Mintex race pads
All new ABS sensors
Suspension
Gaz coilovers
Polybushed all over
Interior
Shell
Full respray 2008
Twin headlights
All new fuel lines
Wheels
4 new dunlop tyres
New badges
Dave
jessie_rs
11
Jun 3, 2019 04:57 PM
