saff shell being stripped for the nsf (passenger) wing
as title, only interested in a genuine ford front wing, ideally im after one with the innner part of the engine bay as i dont want to split the spot welds along the top, want it to look 100% genuine, if anyone is binning a shell locally let me know and il cut it off?
cheers
you need to change your body shop as any panel beater worth his salt can make a wing look a genuine fit
