Rolling Radius / Speedo
Old Sep 8, 2009 | 10:14 PM
1098's Avatar
1098
FIESTAHH
Default Rolling Radius / Speedo
Right, my speedo is too far out as when I am at 40 mph on the speedo it reads 32 mph on them digital signs, at 60mph its like 53 mph or something. I am sure that the wheels are causing this as they are 185/55/14. What tyres will I need to get a similar rolling radius to the 13" with dounghuts that were most probably supplied with the car (I didn't take the original steelies when I bought the car).
I also have another speedo cluster I got from the scrappy that I can always try if the radius is not out.
Thanks in advance.
Old Sep 8, 2009 | 10:39 PM
burnzy's Avatar
burnzy
burnzy
i just adjusted mine to suit i had a mk5 escort and went to 205/55/15 then to 205/50/15 then too 205/45/17 and all i did was pull the needle stop out let it rest it'll spring round a bit to release the tension of the spring, adjust it by eye of how much you think it needs then try again, it's trial and error but i didn't find it too much hassle, i used my sat nav as the true indication and it worked fine i never got caught in a speed camera anyway
try it on your second hand set of clocks first just incase you make a mistake.
P.s to pull the needle off use 2 spoons to prize it off without bending the pin it sits on , putting it back on you have to be careful too that you dont move it otherwise you'll be making it worse hope this helps.
Old Sep 8, 2009 | 11:52 PM
puddy's Avatar
puddy
Try this link, will tell you all you need to know
http://www.carbibles.com/tyre_bible_pg2.html
puddy
1098's Avatar
1098
FIESTAHH
It doesn't spin around when I take the stop pin out :S
Old Sep 8, 2009 | 11:59 PM
RUPERT THE BIG HAIRY BEAR's Avatar
also you wind the clocks back a bit ont he spare set if u fit them and lose a few miles for resale time lol
Old Sep 9, 2009 | 12:01 AM
1098's Avatar
1098
FIESTAHH
Thanks for that website. The tables and calculators where useful. I found an advert for a mk3 steelie and it has a 145/80/13 tyre on it (I'm guessing stock size), so as mine has a 185/55/14 it is correct to the table and only 0.54% out.
As for setting the clocks back, I could do with doing that as the spare set has 48k more on them (Scrap car 88k, my car 130k) xD
Old Sep 9, 2009 | 12:21 AM
are they manual cable driven if so it should be easy to do with a drill the digi ones you can get done for about 40 quid
Old Sep 9, 2009 | 01:38 PM
1098's Avatar
1098
FIESTAHH
Any more light on this matter as my wheels aren't effecting it obviously..
Old Sep 9, 2009 | 08:41 PM
1098's Avatar
1098
FIESTAHH
bump
boeb
Jan 9, 2020 05:11 AM
cossie brad
Sep 29, 2015 02:38 PM
Mikersturbo
Sep 27, 2015 07:43 PM
IainRS1700T
Sep 25, 2015 06:44 AM
