bailey breather.
where do i put the small pipe that goes form the top of the inlet to just behind the left hand rocker breather hole? is it ok to block it off?
Thanks.
and sorry if i'm being dense
Thanks.
this bit at the top of the inlet.
a small pipe goes to this bit, but cant anymore cos the bailey one does away with this bit completly i thought. i 'd just like to know what to do with the nipple on the top of the inlet. is there somewhere else i should plumb it in, it just block it off?
