How does an external wastgate work?
Old Sep 8, 2009 | 12:34 PM
Raj_FRST's Avatar
Raj_FRST
Half Rice Half Chips
Default How does an external wastgate work?
as above, ive got a 2.0 zvh running a t3, i want to installe a external wastegate. Can anyone tell me how they control the boost, what needs to be connected to what etc. I shall be fabricating a bracket to hold the internal gate shut
any help would be great
Old Sep 8, 2009 | 04:54 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
ok, firstly why do you want to run an external wastegate?
secondly it's not so simple lol.
you'll need to cut a hole on the base of the erst manifold and weld a pipe into it before the turbo where all the pipes meet. then run this pipe off and fit a flange for the external wastegate, then a pipe out of this to feed back into the exhaust or just out of the engine bay to wherever.
a wastegate bleeds off exhaust gas this inturn reduces the flow of gas to the exhaust turbine in the turbo, this in turn reduces the boost. if the wastegate is closed it'll just keep spooling and producing big boost, but as a normal wastegate there is a feed off the boost pipes which opens the wastegate to limit the boost.
you vary how these work with varying spring rates in the unit and a boost contoller if you wish.
they are better than internal ones as they help the turbo flow better and react better to boost spikes etc.
p.s. welding steel to cast iron isn't easy and commonly fails due to the intense heat heeded and the slow cooling to make it stay intact and not crack later.
Old Sep 8, 2009 | 06:00 PM
Raj_FRST's Avatar
Raj_FRST
thanks for the reply,
I would only want one for the sound really of the screamer pipe, sad I know, but if its better boost control then it would be a bonus. I have found this adaptor on ebay which I though was a good idea as long as there was room to fit it
http://cgi.ebay.co.uk/Turbo-Adapter-...d=p3286.c0.m14
if it could fit it may be worth a go
Old Sep 8, 2009 | 06:04 PM
RUPERT THE BIG HAIRY BEAR's Avatar
what does a screemer pipe do is this where it flows the by passed exhaust gasses out to atmosphere and i guess there loud if ive worked it out to be correct
Old Sep 8, 2009 | 06:08 PM
Raj_FRST's Avatar
Raj_FRST
thats it mate, do a search on you tube and you will get the idea, I kow its sad but im into mt little boy racer sounds etc.lol
Old Sep 8, 2009 | 06:38 PM
BIG WULL's Avatar
BIG WULL
Fae the Dale
thats actually a nice adapter there..
Dont think its worth all the hassle though mate.
just get a straght through exhaust, that'll be loud
Old Sep 8, 2009 | 07:56 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
you'll stuggle to fit the adaptor in i reckon.
best to get a tubular manifold made, then it can be made better.
Old Sep 8, 2009 | 08:56 PM
Raj_FRST's Avatar
Raj_FRST
will have a think about it, I need to hear one in the flesh to see if its worth it though
YODI
Aug 30, 2015 01:12 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Aug 14, 2015 07:29 AM
