Cam Bearings
Old Sep 7, 2009 | 04:54 PM
Dearo's Avatar
Dearo
Default Cam Bearings
How do you remove and fit new cam bearings on a 2wd cossie ??
Does anyone have any pics ??
Old Sep 7, 2009 | 05:16 PM
Escos2483's Avatar
Escos2483
From: guernsey,c.i.. a rip off island , full of drunks
THERE ISNT ANY ... THEY ARE MACHINED DIRECTLY IN THE HEAD ..
Old Sep 7, 2009 | 06:11 PM
2wd DO have cam bearings, in the form of a normal ball race type.
These simply slide off the cam when the pulley is undone etc, dead easy.
They are in a carrier that is clamped between the head and the front bearing supports.
To do simply loosen belt, take off cam pulleys, undo bearing carrier and other cam posts, lift out cam, remove woodruff key, slide off the front carrier housing the bearing, take out bearing and replace, think it is a circlip holds it in/stops it moving, you'll soon see it's dead easy.
Old Sep 7, 2009 | 06:15 PM
Dearo's Avatar
Dearo
I hope so mate, coz I've just bought some for a Cossie
Old Sep 7, 2009 | 06:41 PM
Escos2483's Avatar
Escos2483
Sorry .. I thought u ment the shell type .. Ball bearings on front as tab said ...
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
