mechanic question
Old Sep 7, 2009 | 04:40 PM
Rob Virgo's Avatar
Rob Virgo
Default mechanic question
my wifes avensis 2.0 d4d is jumpin out of fifth gear since a flywheel and clutch change.boy who changed it has gone to oz so dont see him fixin it.
any ideas,remembered that the linkage on the fwd escorts needed a tool to aligh it or you could get right gears so wonder if this is similar.
box has got a little noisy since the job asell.
ideas......
rob v
Old Sep 7, 2009 | 05:19 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Pretty sure that it is a cable linkage on these - Might be worth dropping it in at Toyota for them to re-align/tension the selector cables
Old Sep 7, 2009 | 05:39 PM
Rob Virgo's Avatar
Rob Virgo
tks graceland,will check that out.....
rob v
Old Sep 7, 2009 | 05:59 PM
C4llyT's Avatar
C4llyT
Sounds like there's little/no oil in it.
5th is first to go as it's on the end.
Old Sep 7, 2009 | 06:18 PM
Rob Virgo's Avatar
Rob Virgo
so you mean its shot 5th gear or a check/top up will sort it
rob v
Old Sep 7, 2009 | 06:25 PM
burnzy's Avatar
burnzy
burnzy
lets hope he put the oil in at the end of the change
if the box is noisy it sounds like it, but to be honest if there was no oil at all it's make a right racket, check it's level and hope for the best could be the linkage but i'd of thought if your able to get into 5th gear it should stay there but i could be wrong
Old Sep 7, 2009 | 06:34 PM
Rob Virgo's Avatar
Rob Virgo
he did put oil in as i saw some of it on my drive way,box seam gasket leaked so lost some but not enough to damage or so i hoped.toyota mechanic as well......
Old Sep 8, 2009 | 02:01 PM
Is it the mk 1 shape or the mk2.The mk1 gearboxes were shite the bearings used to go all the time and they would score the gearbox casing and fook it.
Old Sep 8, 2009 | 03:50 PM
Rob Virgo's Avatar
Rob Virgo
mk2 , o4 tspirit
rob v
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
20/20 vision
Sep 29, 2015 11:27 AM
