Backpressure
Old Mar 3, 2004 | 09:18 PM
Default Backpressure
A mate thinking of buying a Fiesta Turbo said when he looked at one and the oil cap was removed it cut out and it was running a std cam. The question is should it keep running even slightly lumpy or should it cut out. Seemingly on a buyers guide it says it should cut out.
grateful
Any true answers.
Old Mar 3, 2004 | 10:31 PM
owens130's Avatar
owens130
ive always known them to cut out if the oil filler cap is removed but then i dont run the engine without the oil filler cap
Old Mar 3, 2004 | 10:35 PM
Thats what i thought mate just wasnt 100% sure Seemingly on a buyers guide online not sure what one it says it should cut out this is to check for backpressure??
Old Mar 3, 2004 | 11:43 PM
PJay's Avatar
PJay
It will cut out matey, they all do it
Old Mar 3, 2004 | 11:50 PM
what if it stays on?
Old Mar 4, 2004 | 07:21 AM
JesseT's Avatar
JesseT
Then it's running well rich, the breathing has been modified, or the breathing system is clogged up. At least in an RST
If the fuelling system is based on an air-flow meter or is an alpha numerical system then you are just basicly creating an air leak and the engine goes lean, and stalls.
If the system is based on a MAP-sensor, then the air leak just increases the idle revs.
A whole different story is the lambda correction which tries to compensate for the extra air.
The FRST has all these systems, so basicly it's hard to predict what it will do. Depends on too many things.
Old Mar 4, 2004 | 07:52 AM
Cheers mate, just out of curiosity i take it the escort should be the same i havent checked.
Old Mar 4, 2004 | 12:29 PM
Stu @ M Developments's Avatar
PassionFords Creator
Sorry to be an arse, but i disagree... lol
Only the ESCORT rs Turbo will cut out if the crankcase is vented to atmosphere.
The Fiesta is MAP fuelled and as such, should do nothing more than spit oil at you
Old Mar 4, 2004 | 09:27 PM
No the more info the better
thanks
Technical essay Archives
31
Mar 1, 2011 06:35 PM
yrkesman
62
May 26, 2008 06:47 PM
RWD_cossie_wil
Apr 21, 2008 07:02 PM
Stavros
33
Feb 20, 2006 11:22 PM
Stavros
13
Feb 8, 2005 12:30 PM
