Brakes
Old Dec 20, 2004 | 08:51 PM
fernando_khan's Avatar
fernando_khan
Default Brakes
ok i have looked around and have found some information on brake upgrades for the s1...
so the most common is the cosworth conversion (??)... what is needed to convert the fronts to cosworth spec? apart from the calipers..disks...pads?also if i can get my hands on some ap's for a cossy will they fit same as the normal ones?
also what about the rear?? there bloody drums standard...do people change them to disks or just beef up the fronts?? i think i seen a conversion from burton power but couldnt make it out...
cheers
Old Dec 20, 2004 | 09:25 PM
escort1989uk's Avatar
escort1989uk
don't do the ap's won't work i don't think with the cossie calipers you just space them out with a washer or two, or you could upgrade to focus st170 brakes on the front quiet a lot of people run this set up now as better to buy new than old and leave your rear brake till your pushing some high bhp and get a inline bais valve when you do. if you want more advice speak to reyland
Old Dec 20, 2004 | 10:03 PM
fernando_khan
rite well my brakes suck at the mo! like its being stopped by bike brakes or summin...i will be running bout 200bhp...but even if i was running with minor mods i always like sharp brakes... focus st170 brakes are better than 2wd cossie ones??
oh and escort1989uk thanks for the info.
Old Dec 20, 2004 | 10:33 PM
escort frenzy's Avatar
escort frenzy
I put cossy front brakes on my sereis 1, 2wd discs with 4wd calipers and pads. Put Series 2 rear drums on they are 9inch drums where as series 1 are 8 inch.
Old Dec 21, 2004 | 07:17 PM
ballin's Avatar
ballin
focus st170 are the best imo, but require 16's +
if your std or not big power then 4x4 cossie calipers and 2wd discs, fit straight on 1mm washer
i personally wouldnt bother upgrading the rears, they are actually pretty good as std
Old Dec 21, 2004 | 07:59 PM
JesseT's Avatar
JesseT
You can just upgrade the rear cylinders to keep the bias ok.
Old Dec 21, 2004 | 11:06 PM
fernando_khan
no i need some brakes to fit 15 inch wheels..its kind of a must... (cossie rims u c!)
i dont intend to pull major g's with my brakes just something good and sharp and doesnt lock all the time...
i've been looking at www.rs-ford.co.uk and their s1 restoration... must say i like their brake setup and isnt too costl...
cheers
Old Dec 21, 2004 | 11:37 PM
llw's Avatar
llw
cossie rims are 16"
Old Dec 22, 2004 | 12:33 AM
fernando_khan
oh yeh i forgot!! damn not the rs nutter completely yet but getting there... and oh yeh llw.. the ones im talkin bout r in ur basement...lol
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
