Hey guys just a quick one, recently bought a baileys oil seperator for s2 rs but it looks different to others that i've seen whereby it only has 1 inlet port under the can and an extra one on the side?
I've checked threads and they seem to have a different one to mine?
It's an EFI seperator, doesnt have the return to the metering unit at the bottom just one to return to sump, the small one at the top goes to the inlet manifold return.
Yes you can still use it but not like that..... change left side of RC to Venting (small outlet), right side of RC to Left side of RC, Atmosphere to Right Side of RC.
Basically the small outlet cannot go to the RC because it's too small.
Cheers karlos great help!
Guess i wont be able to use the originl bracket though
Ah well so long as it will still do its job
