my engine wont pick up from idle
Old Sep 4, 2009 | 05:35 PM
DANIEL p's Avatar
DANIEL p
LOVE FORDS
Default my engine wont pick up from idle
just put new engine in my car the car starts and idles but as soon as you touch the accelerator it dies any ideas have good spark on plugs
Old Sep 4, 2009 | 05:58 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Check for air leaks along all pipes and around the metering unit first...
Old Sep 5, 2009 | 10:33 AM
mark2's Avatar
mark2
as said check for air leaks and if it is mfi setup an airleak on mfi is a nightmare
but i would check the co2 as your new engine is going tobe fresh and breath different to the old one so could be co2 related
i would start by getting someone to set the car up, if you have a co2 tester (halfords do one about Ł75 ) see what the car is as it idles then take it from there at a guess i would say to high only coz i have been there
could be worth a try if you know its all piped up properly and all electrical connections are tight and clean
mark
Old Sep 5, 2009 | 10:39 AM
Herbo747's Avatar
Herbo747
Does it idle properly at around 800-1000 rpm? Then die on accelerator, the mfi setup works on crankcase pressure, if anything like the oil filler cap, dipstick is out it wont run properly. Check inside the fuel distributor that the flap on the air intake is opening properly and also check all connections. I would also advise a full set up with fueling, it makes hell of difference.
Old Sep 5, 2009 | 10:55 AM
Karlos G's Avatar
Karlos G
Balls Deep!
If it is an airleak then it will not idle! If it dies when you press the throttle then it's something else, probably not getting enough fuel to compensate for the big lung full of air it takes when you open the throttle.
Old Sep 5, 2009 | 11:11 AM
Herbo747's Avatar
Herbo747
a minor air leak will cause it to still idle, just not very well thats why i asked, and if you read the rest of what i put its what you have said anyway!!!
Old Sep 5, 2009 | 12:04 PM
jodyhoare's Avatar
jodyhoare
as karlos said, an air leak would cause the car to stall all the time.
i think it will be something to do with the metering head, either fuelling as stated or "flap" ceasing, EMFPA etc.
Sheepdisease
Aug 30, 2015 09:11 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
Zoggon
Aug 10, 2015 10:39 AM
