Reverse light help..
Old Sep 4, 2009 | 12:48 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
Default Reverse light help..
Can anyone direct me to the relevant fuses controlling the reverse light on a Y reg (2001) 3dr Focus please?
Fitted aftermarket fog and reverse light and reverse isn't working..
Have checked the wiring as far as I can trace it.
Cheers!
Old Sep 4, 2009 | 01:44 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
Ok, on further inspection, I have taken out the centre console and found corresponding wires.. (Black and Green/Yellow) They're attached to a plug which isn't connected to anything and nothing/nowhere obvious to plug into.
Any ideas?
Old Sep 4, 2009 | 03:13 PM
RichieST's Avatar
RichieST
The plug is for traction control, which would be plugged into a switch if your car had it. You getting voltage at the bulb holder?
Old Sep 4, 2009 | 03:17 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
Nah, its not traction control, thats plugged in. No voltage at all.
Old Sep 4, 2009 | 03:22 PM
RichieST's Avatar
RichieST
Probably a heated seat plug or something then. The reverse light switch is in the gearbox.
Did it work before you put the new light in?
Old Sep 4, 2009 | 05:28 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
Couldn't tell you the last time it worked, car hasn't seen the road in a while. Ok.. I'll rule that plug out then.. Any idea on the fuse side of things?
Old Sep 4, 2009 | 05:43 PM
RichieST's Avatar
RichieST
I don't know mate, I'll have a dig about for my handbook tomorrow and look for you
Is there anything else electrical that doesnt work?
Old Sep 4, 2009 | 06:14 PM
CarbonRick's Avatar
CarbonRick
PF Village Idiot
The blowers.
Everything else seems fine. Cheers pal!
stevecfrst1
Sep 30, 2015 05:18 AM
deathrider666
Sep 28, 2015 06:12 PM
Sep 28, 2015 10:05 AM
The Enigma
Sep 12, 2015 10:12 PM
